I have a few questions about hose sizes (ID, OD) for the windshield washer hoses. Any comments or advice would also be appreciated.
#1 - I measure the hoses from the anti-drip valve output nipple to the "T" and the hose to driver wiper arm as 3/16 ID & 3/8 OD.
#2 - I measure the hose to the passenger wiper arm as 3/16 ID and 5/16 OD (thinner wall than #1). I believe this hose is original because it has black sealant on it at the wiper end like several areas in the plenum.
#3 - The hoses from the pump output to the the anti-drip valve were missing but I want to reconstitute the whole system.
I purchased a hose kit from Paragon. However,
#4 - The various lengths of hoses are the same. I understand that Doc Rebuild's are not the same.
#5 - The kit I purchased, does not include the "T" mentioned in #1 above and mine is broken. The base/inlet of my "T" is larger than the two outputs/arms and it is solid black in color. Does anyone have a source for these?
#5 - Since the pump to anti-drip valve hoses are missing altogether, I also need a "T" or "y" to combine the pump output from the two nipples to the one inlet of the anti-drip valve. Am I correct about the "T" or "y" and does anyone have a source.
I have looked in my AIM and researched this site and found a lot of good information but not these answers. Many thanks to those who respond.
