DOA: Corvette Repro�s (or soon thereafter)
- Top
William-------
1967 used a one-year-only evaporator core. So, all you have to do is to find an NOS GM #3003071. Of course, it's VERY difficult to find and will almost certainly cost a king's ransom if you do.In Appreciation of John Hinckley- Top
1967 Air Conditioning Evaporator Core Assembly Reproduction of GM 3003071 CAVEAT EMPTOR: our authentic AC evaporators feature Aluminum finned cores as original, pre-formed heli arc welded core inlet & outlet tubes & liquid bleed line manufactured in the USA; not imported. NOTE: connect the upper tube to the STV valve; the lower tube to the expansion valve & the bleed line to the side port on the STV. SHIPPING: on these is based upon the final destination. They are not eligible- Top
William, Call Classic Auto Air in Tampa Florida, ask for Mike. What you will need to do is send them your old core and they can transfer the pipes to the new core. They don't make a correct one for '66 or '67. I am having to send mine to Old Air Products in Texas with the same problem. I ordered a evaporator core from Paragon and the POA valve brackets did not line up with the housing brackets. The core came from Old Air Products. Email me and I can send you some pictures. Not happy because I had to dissemble it, pack it up and send both units, lost time, shipping, etc.
Yes Joe is correct, 66 is in a year by itself along with '67. I have gotten an education on evaporation cores- Top
