Interior Quarter Trim Panels Vinyl and Paint - NCRS Discussion Boards
  • Larry M.
    • January 1, 2002
    • 535
    Were these panels made of the correct color vinyl originally or were they a common vinyl and painted to interior color?
    If the second is true then it makes sense that the screw eyelets which are crimped in place would be painted also. Shold they be painted or not?
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Interior Quarter Trim Panels Vinyl and Paint
    The quarter panels on the coupes were covered with colored vinyl along with all of the other interior items that used vinyl. No spray dye and the metal eyelets should be bright finish, not colored.
    • Gene M.
      • April 1, 1985
      • 4232
      I assume you are referring to '67 and prior build. The '68 interior is another matter on the screws and eyelets.
      • Larry M.
        • January 1, 2002
        • 535
        Yes...should have said C2-64. My eyelets are red so my panels are either refreshed with dye or paint...but I can clean them.
        Thanks for the responses
