LT1 spark plug wire remove - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    Is it best to warm motor to release spark plug wire?
  • Leif A.
    • August 31, 1997
    • 3607
    Re: LT1 spark plug wire remove
    Frank,
    I don't think that's necessary. Firmly grasp the boot and rotate it on the spark plug, then give it a good pull. After installing the new plugs, put a dab of dielectric grease around the end of the new plug (before installing the boot) to make it easier to remove the next time.
    Leif
    • Keith B.
      • September 15, 2014
      • 1575
      Your going to be saying every cus word in the book on the drivers side. No need to make things worse with a hot engine
      • Mathew S.
        • July 9, 2015
        • 136
        Drivers side is a piece of cake. The passenger side isn't that bad till #8 plug. It helps to loosen the ASR so it can be moved, as well as taking out the cover over the a-arms. If you're changing wires, that is no fun. Also be careful around the fuel line holder as they can break and not sure if still available.
