Gents, My first time fuelie install so I have about a thousand questions coming.....
I've looked at every document I can think of but nowhere can I find the proper configuration for the distributor cap orientation. If it exists somewhere please inform me. The AIM is no help.
Does it mount this way.......? Note black coil- wire at the rear. Me thinks this is it as most non-FI distributors act this way. However one of the cap windows faces the back of the plenum, so that is confusing.
Or does it mount this way.......? Note black coil- wire at the front. This way the cap windows are easier to get at.
Also, is there a particular orientation for the clamp screw position? Access from Driver or Passenger side, front, rear, side ???
Rich
Rich
), coolant, and fuel it up. I have 5 gallons each of 100 Octane and REC 90(non-ethanol) and planning a 50/50 recipe. BTW the engine is stock RPO 582, using CS133R cam and AT992 lifters, 461 heads(decked) with Felpro composition gaskets(0.039" CT) to get me finished around stock CR.
