1963 steering box color conundrum. With pictures
Tags: None
- Top
Re: 1963 steering box color conundrum. With pictures
Well the paint is certainly not the asphalt or tar based paint Joe spoke of. I will likely strip the box of the rest of the paint using paint stripper. Then finish the rebuild and use satin clear on the box and reinstall it.
Rick- Top
I agree with that observation, it very well could be the original black.- Top
Maybe replacement steering boxes were painted but how can you explain the either yellow or green inspection marks on original boxes if they were painted. Justify that! And no they were not painted over the inspection marks.
JR- Top
Painted black after the box was assembled and inspected, then inspection marks added?Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
I'm not saying this is the way it happened but for the 63 and 64 M/Y black painted chassis parts are often mentioned.- Top
No if the inspection marks are present they are under the black out!
The inspection marks go on after the box is set up properly.
If the inspection marks exist (either green or yellow) they are always observed on a bare non painted or partially blacked out steering box.
JR- Top
Then how come owners have mentioned black painted steering boxes on original cars in the past.- Top
Thanks to everyone that responded.
I went back and noticed the frame was indeed painted under where the box mounted. I am now assuming I painted the box some 30 years ago.
I also stripped the box and found what I thought was primer, of course GM never used that! So I stripped the box using paint stripper and then wire brushed the box. Then cleaned it and used Eastwood's Satin Clean. Pictures below;
I am planning on adding the inspection marks after it is assembled.
I really appreciated everyone's input on this.
Helps me sort things out and not over think the situation.
Rick- Top
Does anyone know what the correct finish for the large lock nut?- Top
Joe and others are right. The steering boxes were painted at Saginaw with a low quality black paint. Mike Hanson once commented that the black steering box paint would peel off with a car wash water sprayer. It doesn't sound like you have factory paint on your steering box.Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
Original member of the Kansas City Chapter, est'd 07/11/1982.
Member: 1965 and 1966 National Judging Teams
Judging Chairman--Kansas City Chapter.
Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
- Top
According to John Hinckley paint was not required at the Saginaw facility however some were painted. Those that were painted did not show an inspection mark because the paint was over the mark. Ones that were not painted show the inspection mark.
Apparently earlier ones 63-64 were less painted.
That would leave the door open to the restorer.
If you are going to get your Corvette judged you better contact your team leader for your year Corvette.
JR- Top
- Top
