Is there a bench test for the battery gauge, i.e., a known voltage should produce a known deflection?
I've chased the usual suspects but no success. My 66 gauge only deflects about 1/16" even with headlights on and raise lower. No negative deflection on engine startup. Been this way for 15 years and 2 batteries
I've checked electrical connections including bulkhead connector, I have 12 volts on both sides of the gauge ( I know the gauge is a sensitive voltmeter) and the needle deflects to -40 or +40 when "flashing" the terminals with a AAA 1.5 volt battery.
I'd like to know the gauge is defective before going to the trouble of pulling the cluster and replacing it.
Randy
Randy
