WCFB carb problems
Re: WCFB carb problems
Really necessary to replace????? give me your assessment as to the need to do this. It begs the question of WHAT can go wrong with a steel ball????? so why?? I saw the cover and tried to remove by picking at it but to no avail. so it did not get replaced obviously or I would have seen it. On Q-jets I can see where the ball goes if I remember right but that too has been a long time. Thank you once again, Mike- Top
P.S. I use a product called "Seal-all" for sealing plugs , especially in Q-Jets, that works great.- Top
I've only removed those steel check balls when I've seen somebody before me had boogered up the thin metal cover and that had to come off anyway.
A properly sized, long 1/4" drive socket, lightly tapped, will seat the replacement cover nicely. Otherwise, they aren't worth fooling with....- Top
