After running engine in garage for about 20 minutes idling between 1000-1500 rpm's, I pulled a plug out for inspection since they seem to be fouling prematurely. As I suspected the plug. I checked was black with carbon.
The plug I'm using is a Accel short plug(due to headers) 576S. Engine is a built up 301, carb is 4776S, stock dist.,compression between 160-170, dwell about 35 degrees,
Any suggestions what else to check or is the plug too cold for this engine.
