1967 Battery Mishap - Burning smell - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 1967 Battery Mishap - Burning smell
    Originally posted by Gene Manno (8571)
    Is not the fuse link at the voltage regulator?
    Gene, There are 2 at the VR to protect the alternator and VR wiring.
    2 at the starter solenoid feed supplying the horn relay buss bar and the Battery Meter source terminal.
    1 at the horn relay buss bar as the source for entire car electrical load.
    Here is a Early 1967 harness. VR/Alt section, 2 links.
    Early type with the separate Plug-Type fusible link at the horn relay buss bar. Later cars and service replacement harnesses used the black barrel type joint as shown above.
    • Gene M.
      • April 1, 1985
      • 4232
      Thanks Rich, great pictures, Two fuse links at VR. I completely missed the fuse link at the horn relay as mine are dressed up close to the inner fender and the core support on my silver car. And I stand corrected also tucked up in same area is the separable fuse link on my early white car. I must be getting old, forget my head if it weren't attached.
      So I can now correctly confirm a plug in fuse link for #440.
      • Frank D.
        • December 27, 2007
        • 2703
        #18
        So much for letting the keyboard jockey at the FLAPS store figure out what is needed based on the incorrect data in his computer for a 50 year old car...
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          #19
          That's good info Gene. That old harness I have here with the same plug in Fusible Link is the original from #4136, a November '66 build. You'll read about that car in the Summer edition of the Restorer. Jim Gessner and I did a story about it. I replaced the forward harness as it was quite tired and badly corroded at the bulkhead pins. The fuse panel was fine except the panel Twinlock on the big-red-lead which I repaired.
          Yes, those Group 24's are often confused. Just today I picked up a contemporary AC Delco Group 24 for a '61. It's especially nice because it has no carry handle extensions on the ends which typically have to be cut off to get the shield over them.
          • Ira Z.
            Infrequent User
            • September 30, 1996
            • 5
            #20
            Rich: Thank you for your offer. I have a local corvette mechanic who will be doing the repairs as this is beyond my level of competence. I will mention your kind offer and will let you know if I need to take you up on it. Ira
