C2 small block radiator installation - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    I struggled with the radiator installation on my 67 small block. I thought I would post what work.,
    Remove the fan, pulleys and hood.
    I installed the shroud and the radiator at the same time, using duct tape to hold them together. The tape made it easier to handle both at once. Be sure to place the tape where you can remove it when the two are in place. We rotated the assembly so the passenger side was on the bottom. Once the shroud cleared the water pump shaft, the assembly was rotated to the normal position,
    Hope this helps,
    Randy
