63 P/S Slave Cylinder Rebuild - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5258
    I'm rebuilding the P/S slave cylinder on my 63. The rubber grommet on the piston end is just too thick as I can not get the C-clip to set in place. There are only three parts on that end, the grommet, the copper colored washer and the C-clip.
    Anyone have the part number of the original grommet or a supplier that has the correct size grommet.
    The stud end went together in 30 seconds.
  • Rick A.
    • July 31, 2002
    • 2147
    Re: 63 P/S Slave Cylinder Rebuild
    Harry - azzume you have checked Zip, but in case you did NOT, they have several different rebuild kits available
    Buy Corvette Power Steering Pump Ram (Cylinder) online at Zip. Specializing in Chevrolet Corvette Parts since 1977. Same day shipping. No-Hassle Returns.
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
      Harry------
      The individual components of the piston end seal system were never available separately from GM. They were available only as a kit. That kit was GM #5686382. However, it was discontinued without supersession more than 10 years ago.
        Harry-------
        I dug one out (fortunately, it was not too difficult to get to). Here's what the GM kit looks like:
        • Harry S.
          • July 31, 2002
          • 5258
          Thank you....
