C2 wiring harness straps - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    My question is in regard to the two hole plastic straps that fasten the wiring harness to the left fender of a 67.
    Which hole should I use?
    Thank you,
    Randy
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: C2 wiring harness straps
    Randy,
    I'm not sure if this is gospel or not, but I use the hole that best fits the harness. The forward harness on a '67 heading to the VR is thick, so IIRC I use the larger ID so the outer hole. As it gets to the core support, with less wires, I use the smaller OD, the inner hole.
    If the car is K66 TI equipped, I use the larger OD, outer hole, for everything, as both Forward and TI Harnesses have to pass through the ties.
    Rich
