Leaking Carburetor - need advice - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Re: Leaking Carburetor - need advice
    Over tightening fuel bowl screws whether a fuel injection or a carburetor results in warping the bowl.
    • Dan A.
      • February 1, 2004
      • 212
      I agree with those that suggest trying it yourself. I spent hundreds of dollars with a reputable carb rebuilder and my Holley never did run right. Between YouTube and other internet sources I was finally able to fix it myself. I would recommend buying the rebuild kit from Holley if you decide to tackle it yourself.
      • Philip A.
        • February 26, 2008
        • 329
        #18
        Dan
        Can you advice which Holley rebuild kit number would be correct? I went to their website and was not sure which was the one needed. Thanks.
        Phil
        • Dan A.
          • February 1, 2004
          • 212
          #19
          Originally posted by Philip Arena (48654)
          Dan
          Phil
          Phil,
          What is the list # of the carb?
          • Anthony F.
            • February 7, 2014
            • 79
            #20
            Assuming you have the factory carb (or correct service replacement), the rebuild kit is part #37-1539 (I actually got through to the Holley Tech Line, that's what they recommended). It's about $115. It worked for me. There might be a cheaper alternative (it contains a lot of parts that weren't used), but that is what Holley would tell you.
            • Dan A.
              • February 1, 2004
              • 212
              #21
              That is the one (or the equivalent) that I got. I wanted the extra parts that came with it.
