65 m21 shifter handle - reduce stick height
Re: 65 m21 shifter handle - reduce stick height
The correct shifter can be found at Volunteer Vette 1 865 521-9100 or you can just purchase the shaft for a 64-67 SH006, 68 and up shifters have longer shafts but the lower end is the same on all thru 81.
JR- Top
The stock shifter handle did not have an adjustable height IIRC.- Top
I was aware that the 68 up shifter was taller than the mid years.
Just out of interest what is the actual difference in height?
Why did GM make it longer, that just increases the throw?- Top
