AC Delco Battery for a 1966 427 c.i.? - NCRS Discussion Boards
  • Bob A.
    • April 1, 2003
    • 172
    What would be the current AC Delco Battery closest to the original for a 1966 427 c.i.? The local AC dealer suggested an Advantage Series 24A which has the following specs:
    Size: 10 1/4" x 6 1/2" x 7 3/4" to top of case/8 3/4" top of post
    325 cca
    18 mth.
    $66.99
    Note! Any comments or suggestions would be greatly appreciated.
    Bob Adams
    Re: AC Delco Battery for a 1966 427 c.i.?
    325 cca
    18 mth.
    $66.99
    Bob Adams
    Bob------
    You need a group 24 battery as the dealer suggested. However, if it were me, I would not go with an 18 month battery. I'd go for the AC Delco battery with a 60 or 72 month warranty.
    • Kenneth T.
      • April 27, 2009
      • 83
      Hi Bob,
      If you want to have a correct replacement try this:
      Fortunabola sebagai situs mesin slot menyediakan permainan slot online deposit dana dan qriss tanpa potongan dengan berbagai permainan slot gacor 24 jam terbaru dan gampang menang.
      They work great also.
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 831
        Bob, I agree with Joe. Use the Delco 24PG. That is the Gold model. I have had great luck with these. Size is good for using the original battery hold down.
          • 15610
          325 cca is waaaaaaaaaaaaaaaaaay inadequate for a 427. I have a 15 year old forty dollar Johnson Controls Group 26R that I use in a couple of cars, ( a 2.2L I4, and a 2.6L I6) that is smaller and lighter than a 24, but it has 440 cca, and I think current 26Rs are over 500 cca.
          You need at least 500 cca and 700 would be best.
          Group 24 is the correct physical size for all C1/2, but cca ratings vary. Higher cca means more densely packed plates, and will, of course, be more expensive, but a big engine needs big cranking amps.
            Duke------
            The AC Delco 24-5YR (60 month) battery has a rating of 525 CCA. That's the highest rating of any current Delco group 24 battery. To get a higher CCA rating in a group 24 battery, he'd have to go with some other brand (assuming that some other brand would have such a battery).
            • Bob A.
              • April 1, 2003
              • 172
              Many thanks for all of your valued and appreciated comments and suggestions. I will make a much better choice due to this forum.
              Bob Adams
