Converting '70 Muncie from M21 to M20 - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    My '70 came with a wide ratio M20 transmission that someone changed to a close ratio M-21 gear set. What exactly do I need to convert back to a wide ratio M20? From my research in parts books, etc., it appears that I merely need to change the counter gear set.
    Thanks in advance.
  • Peter M.
    • May 30, 2013
    • 358
    Re: Converting '70 Muncie from M21 to M20
    Stephen,
    Input gear and cluster. I am doing the same thing on my 67.
    Kind regards
    • Stephen B.
      • April 1, 1988
      • 876
      Thanks Peter. I have to replace the input shaft anyhow as it has 2 broken teeth.
