Tools for KH spinner and lifting the car - your oppinions and recommendations - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 341
    I have got a '65 Corvette with KH wheels (repro) and previously I neither worked under the car nor removed the wheels. At the moment I'm considering enhancing my tool equipment BUT I'm not sure which way to go:
    Either buy a car lift (could remain under the car, 2-column lift not suitable for my garage)
    for ~3.000$ (lift is made in Germany - the professional extended version - sorry description is German) or buy a floor jack together with 4 jack stands and a cross beam to lift the Corvette per axle to minimize frame torsion. Alternatively a car ramp could be an option, too. However removing the wheels would require further consideration.
    I'm reluctant to use a lead hammer for the spinners since I have no experience. There is an alternative (beside buying direct bolt on wheels):
    Rudge Wheel Knock off Spinner Removal Tool for Corvette COV-3 - If you order this tool please do not pay immediately. We will inform you in time about payment when the tool will be available. Thank yo
    together with the appropriate torque wrench (300Nm) and long ratchet.
    Your thoughts and opinions are highly appreciated.
    Oliver
