I have a friend who would like to know the procedure to diagnose this including how to access the terminal. Thanks
1982 Check Engine Light
Re: 1982 Check Engine Light
Mark
OBD-I Troubleshooting - GM OBD 1 Paperclip test - This test ONLY applies to GM vehicles with the 12 pin ALDL OBD connector. http://www.3800garage.com/obd1.jpghttp://www.3800garage.com/obd1.gif To check your computer for stored codes, open up a paper clip and insert one end into the A slot and the other end into the B...
Once he gets the code(s) from the blinking light Google will tell him what the code(s) mean. Of course I have to point out that those of us who work on our own cars find it worthwhile to invest in Factory Service Manuals that will give us answers to the above and so much more. They are not inexpensive, but they will save one a lot of money in the long run.Terry- Top
Mark
Terry and Mark-------
There are many 1982 Corvette factory service manuals on eBay right now, many for less than 50 bucks. As I've said many times before, if one is going to do ANY service work on their car, one needs to have the factory service manual. Does not matter if the car is a Corvette or any other.In Appreciation of John Hinckley- Top
JoeTerry and Mark-------
I didn't realize that used manuals were that inexpensive. Thanks for the up-date.Terry- Top
Mark,
The ALDL connector is located in the center console under the ash tray. As mentioned in the video, sometimes they are upside down. The factory manual is the best source for the pin orientation and procedure to display the error code sequence lights. For several years, at the end of a PV, I would inform the owner it was time to check for error codes and they were very surprised that 82s had stored error codes.- Top
