67 Teal carpeting - NCRS Discussion Boards
67 Teal carpeting
  • Tim S.
    • March 1, 1989
    • 124
    67 Teal carpeting
    I am sure this has been asked several times, and I know no replacement carpeting
    is full credit, but who sells the best original open loop carpet for 67 car?
    Also same question for 67 under car exhaust system, I think there was a company in Indiana that
    used to have a pretty good system. Was it Allens?
    Thank
    You
  • Curt S.
    • April 30, 1975
    • 64
    Re: 67 Teal carpeting
    Yes . Allen stainless exhaust in Logansport, Indiana. Mike Allen is there almost all the time and makes a very good product in my opinion. Hope this helps Curt
    • Gene M.
      • April 1, 1985
      • 4232
      Talking about '67 teal carpet there is nothing available that is even close to the correct color let alone weave.
      I seem to recall Auto Custom Carpets fit well. Correct weave not so much. Correct teal color again not so much. Pinch welting not even close.
      I hand dyed the closest lighter color that was available and hand sewed the original pinch welding thru original holes on to the new carpet. So I ended up with good representation of the original except the weave pattern and density is not correct. I think you will find the repops are a looser pile and not straight weave pattern as originals.
      Sorry no easy solution here.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        I agree totally with Gene. Nothing is close. I went through this over 5 years ago. However, the closest set regarding configuration like heel pad and color is Al Knoch. The binding shade was off though.
        Shy of scouring the planet looking for a original set, then restoring any condition issues, is the only way you'll get satisfaction.
        Here's a old thread with some samples and info from my hunt for teal then. Also has Gene's recipe to make your own set and dyeing it.
        https://www.forums.ncrs.org/showthre...282#post530282
        Rich
