What is the factory torque rating for the 69 L46? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    Guys,
    What is the factory torque rating for the 69 L46? I've checked a couple of sources and they all say 360ft/lb but that is the same torque listed for the base 350/300hp engine so I'm guessing it's wrong. Anybody have a spec on that?
    Mike
    Re: What is the factory torque rating for the 69 L46?
    Originally posted by Michael Leonard (46610)
    Guys,
    Mike
    Mike------
    The spec that I have is 380 lb/ft at 3,600 RPM. Actually, the 300 hp 350 has the same torque peak but at 3,200 RPM.
    • David H.
      • June 30, 2001
      • 1485
      Mike,
      The GM Archive document (page 88 of the pdf) shows 380 lbs. ft. for both the 300 hp and 350 hp engines (3200/3600 rpm respectively).
      Document also shows all 427 ci (390/400/435 hp) as 460 lbs. ft. (rpm 3600/3600/4000 respectively).
      Dave
      • Mike F.
        • April 25, 2011
        • 668
        And in the real world, my 70 L-46 made 341hp/387tq (Engine dyno) and 245hp/305tq (Chassis dyno).
        • Michael L.
          • December 15, 2006
          • 1387
          OK thanks for the info. I just had my dyno session for my 69 L46 a couple of weeks ago. I was unable to tune it at all with only a single pass on the dyno after break-in due to a pesky oil leak from what turned out to be a cracked oil filter bypass plate. It made 351 HP and 411ft/lb of torque. It was a stock rebuild but I did put a mild hydraulic roller in it, mostly for insurance against wiping out a cam lobe than for performance. I was just curious about what the factory torque specs were.
