54 slow turn or no turn - NCRS Discussion Boards
  • Al E.
    • September 5, 2011
    • 313
    My sweet baby hasn't started in years.. 52 years. I have replaced the started solenoid and took it to get tested it kicks over on the bench and is fine. When I put it back on it just clicks.. and clicks and maybe she turns over.. maybe not... it takes about 7 tries to get it spinning. But I have cleaned the batter cables so these are in great condition free of dirt and oil. The battery is new and is fine, she is not locked, when she turns she is free and clear.Any ideas..
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 54 slow turn or no turn
    Al,
    Have someone check the CCA of your battery. Voltage may be correct but the (cold cranking amps) CCA is what gets the engine to turn over. Had a 700 CCA on my 96 that only had under 300 CCA when checked. Occasionally it would just click and then turn over after trying it again. And yes, I did check and change the starter before I bought a new battery to solve my problem.
    JR
    • Al E.
      • September 5, 2011
      • 313
      Thanks JR. Ill Try having it tested. I bought it from NAPA its stated to have 640cc. I don't know what the standard for this car is. But I just bought the 2nd battery a few hours ago.
      • Eric E.
        • November 1, 1998
        • 254
        Ground issue?
        • Al E.
          • September 5, 2011
          • 313
          Maybe, but not the battery cables. I took them off and cleaned them got grease off, no breaks no splits.. Just not sure what to do. Ill try to bolt the ground cable to the frame and see what happens. This car has a starter relay... could this be an issue? can these be bought or bypassed?
          • Tony R.
            • April 19, 2017
            • 201
            Is the plunger solenoid operating correctly and engaging the starter gear in the flywheel ring gear? Ours needed a lot of cleaning and attention after 30-some years of storage.
            • Al E.
              • September 5, 2011
              • 313
              Tony, I did check this and it was ok. I bought a new one from solenoid from AZ and had it tested. It popped out and spun. The flywheel is clean and no broken teeth. I will try a remote starter tomorrow.thanks
              • Chuck W.
                • May 31, 2002
                • 257
                Wrong flywheel or wrong starter?
                • Chris S.
                  • January 1, 2000
                  • 1064
                  Check your grounds - The neg is bolted to the transmission bolt where the dipstick attaches.
                  They dont spin quickly - more like a tractor....
                  Check your shifter and make sure the N safety switch is working correctly
                  1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                  Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                  1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                  1957 Corvette - FI 3 sp - Black and Silver
