Need help with Muncie numbers? - NCRS Discussion Boards
  • Kevin P.
    • November 1, 1975
    • 86
    I have a Muncie trans with the following numbers can someone tell me what it is year-m2o-m21-m22?
    side cover-3884685
    tail-3857584
    main case-3885010
    date-P0614. P-Muncie- 06 June- 14 day of month
    No rings on input shaft
    do not know year as no vin number on. It
    any help please?
    THANKS KEVIN 775
    Re: Need help with Muncie numbers?
    side cover-3884685
    tail-3857584
    main case-3885010
    any help please?
    THANKS KEVIN 775
    Kevin-----------
    GM #3884685 side cover------1966-68
    GM #3857584 extension housing------late 1965-69
    GM #3885010 main case--------------1966-67
    So, I'd say this is a 1966 or 1967 transmission. Of course, it could also be a transmission built up from various pieces.
    • Kevin P.
      • November 1, 1975
      • 86
      Thanks joe, i was told the date codes with the year in it started in 67 ? So i am thinking it is a 66. Thanks kevin 775
      • Kevin P.
        • November 1, 1975
        • 86
        Where it does not have any rings on the input shaft maybe a M22??
          Kevin------
          Yes, date coding which included the year began for 1967.
          No circumferential grooves on the main shaft could indicate an M-22. However, many aftermarket input gear shafts, once widely available and used to service Muncie transmissions, did not have such grooves regardless of which Muncie variant they serviced.
          • Jim D.
            • 2882
            No VIN, not an original Corvette trans.
