1967 coupe body vibration - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1575
    need some help as this has got my dad and I stumped. on his recently body off resto on a 67 BB auto with AC when there is no one in the passenger seat while driving there is a vibration, shake and or rattle coming from the passenger side cowl, dash door area. but while there is a passenger in the seat it does not do it. I checked the body mount bolt and its tight. the door hinges are tight and the door shuts very well. the dash and glove box are all tight. what should I look for
  • Tom K.
    • February 26, 2008
    • 167
    Re: 1967 coupe body vibration
    Did you check the seat mounting bolts and hardware? Could a reinforcement plate have been left off or not installed properly? I'm not at home tonight so I can't check mine or the manual. Just a few thoughts from memory. Mine is still apart.
    Tom
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Likely a tire/wheel issue.
      Just went through a similar issue on a car. Swapped pairs left/right. Problem moved. Rebalanced all 4. All better.
