I had planned on using Krylon 1613 semi-flat black on my Instrument Cluster, but its poor performance on the steering wheel hub and steering column bezel have caused me to doubt its suitability. In the past, Krylon 1613 (lacquer based) always produced a smooth even painted surface, but when I used it on the steering wheel hub and steering column bezel it resulted in massive fisheyes. The steering wheel hub had been carefully glass beaded which is usually the best preparation. After many unsuccessful attempts at wet sanding and respraying the steering wheel hub, I glass beaded the paint off again and primed the hub. The primer prevented most of the fisheyes when the Krylon 1613 was reapplied. However, the original paint on the hub and the instrument cluster were used without primer.
The original paint on the cluster seems to be applied over the shiney casting without glass beading or primer. Have any of you had success with Krylon 1613 spayed on a shiney instrument cluster? Is there a better paint for instrument clusters? Do you have to prime the cluster unlike the original paint? What preparation do you use?
