Anyone replace the front press in plug on a master cylinder for a gen1 vette? Process?Special tool needed?Or is it best left to a brake shop?
57 vette master cylinder front plug replacement
Re: 57 vette master cylinder front plug replacement
Joe I would have it done by a domestic expert with experience.
I send my MCs to Apple Hydraulics in NY for sleeving. I'd give them a call as they may be able to do it.
If you loose that plug in a panic stop, not good.
Rich- Top
Why are you screwing with a safety item like a master cylinder ID in the first place? The original part was engineered with specific perameters (sp) and test procedures. The engineering print required the plug ID number be inserted to verify the part meets all these standards.
Suggest you advise any future owner of your car the master cylinder plug is a fake! and he brakes at his own risk.
NCRS gone crazy!!!- Top
Since when is curiosity a crime?Condemnation for asking a qurestion?.Next week I'll plug the nail holes in my 20 year old tires and sell it to some unsuspecting victim.Your outrage is misplaced and your suggestion not appreciated.- Top
I DISAGREE WITH IT BEING A SAFETY ITEM. Since you think it is a safety item, tell me what the difference is between a cylinder with a 320G and 320H plug? Also, all delco replacement cylinders come with a blank front plug. if the engineering print required the plug ID number be inserted to verify the part meets all these standards, why do the replacement cylinders have a blank plug?Why are you screwing with a safety item like a master cylinder ID in the first place? The original part was engineered with specific perameters (sp) and test procedures. The engineering print required the plug ID number be inserted to verify the part meets all these standards.
the reason is a 320 G plug is the correct and only plug on a early corvette. delco replacements have a blank plug and the cylinders with the 320H plugs are know to not originally been on corvettes. so most likely the cylinder has a blank or 320H plug.- Top
