Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
427 BB front pad stamp if it's the real deal -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Big blocks were stamped with the head off. According to John H. the gang holder had a locating tang that rested on the front of the block to prevent the stamp from being too far rearward and not readable after the head was installed. If you compare this pad to known originals, the stamp is too far forward. My vote is it's clearly a re-stamp.
wouldn't the front stamp pad will confirm that it's is a original block and engine for that car
You can't determine an original engine and stamp pad vs. good fake from a photograph anymore accurately then differentiating an original oil painting vs. a good counterfeit.
Well i like to see a real 427 BB stamp pad then to compare if that the case, so how do we know it a fake or real then, if the number are so perfect what is the real DEAL then, so how do we determine an original engine and stamp pad then ?
So they say this is a Original engine stamp pad on 67 427-435 BB and the guy want 275k for his car so does anyone think this pad is the real deal or is this the way a real front pad should look like , i,am very confused ?
VIN 3640 left the factory in Nov 1966. The engine is stamped T0316, which would be March 16, 1967. Am I missing something here? How could it possibly be correct?
This pad is nothing like an original stamping. The other one was closer to original appearance, but the "J" looks too small, and the build date would be good for car 13640 not 3640.
Yes i notice that too that a 5 months spread from birthday to stamp code, so what is the rule of thumb from birthday date to stamp pad code is up to 2 months is fair to say to be good.
Up-close in-person inspection (not pictures) and years/decades of experience. The obvious fakes are easy to spot, it's the top quality restamps that are hard.
Re: Need help on birthday date and Stamp pad engine date
Patrick, cast block is 3904351 , 427bb 435 i don,t have Cast block date, birthday is 103640 Nov.12/ 66 pad stamps is T0316JE which is Mar.16/ 66 or 67 that what where i,am stuck at is it 66 or 67 on the pad so what happan if the block cast date is in 66, appreciate any feed back
