CI RPO BB "Look-a-like" drum Corvette Restorer Article - NCRS Discussion Boards
  • Tom P.
    • April 1, 1980
    • 1814
    Re: CI RPO BB "Look-a-like" drum Corvette Restorer Article
    This is the drum with slightly larger fins after I modified it and cut off the flange.
    • Bob W.
      • December 1, 1977
      • 799
      Tom Thanks for the the pictures.What one is closer to the original.
      Bob
      • Tom P.
        • April 1, 1980
        • 1814
        #18
        The drums from the parts stores are probably closer to the appearance of original HD drums, but I much prefer the ones with the bigger fins which came on the 70s GM cars.
        If there was a way to search through warehouse inventories which supplied GM replacement drums, a person might be able to find some drums with the bigger fins, but I have no access to such sources.
        Once the drums with the larger fins are installed on the car, all that can be seen is the ends of the fins. Thus, larger fins make a better "showing", as seen below.
        Notice the ends of the fins on this drum (replacement drum from parts stores) are not as prominent. I use these on the rear.
        • Al R.
          • June 30, 1988
          • 687
          #19
          Tom, what method did you use to lower the center of the drum to the outer edges, so it was flush across the drum as shown by the wooden ruler? BTW, I could not locate Vol 18 # 4 Winter 2011 of the SACC magazine. Thanks, Al
          • Tom P.
            • April 1, 1980
            • 1814
            #20
            See if this will open.
            Homemade Big Brakes - 7-31-17 compr.pdf
            • Al R.
              • June 30, 1988
              • 687
              #21
              Tom, I want to thank you for the effort you put forth on this, especially the PDF file that Dave helped you with. Thanks go out to Joel also, for the pictures you emailed me. This give me 2 solid options to chose from. Again, thanks for all involved! Maybe it will help others out, also. Al
              • Bob W.
                • December 1, 1977
                • 799
                #22
                Tom Thanks for posting the PDF for everyone. Maybe Richard will add it to his list.
                Bob
                • John F.
                  • March 23, 2008
                  • 2395
                  #23
                  Excellent article even if you don't own a first generation corvette. True "Yankee Ingenuity"!
                  • Tom P.
                    • April 1, 1980
                    • 1814
                    #24
                    I'm sorry, I'm not understanding your comment???? These home made HD brakes are on my 56. Is a 56
                    Corvette not a first generation model?
                    • Al R.
                      • June 30, 1988
                      • 687
                      #25
                      Tom, I think he might have meant that "He" didn't own a 1st gen. vette judging by his C2 avatar.
                      • David Z.
                        • April 1, 2002
                        • 181
                        #26
                        I'm with Al Tom. Looks like he's paying you a compliment on a nice upgrade to the C1 Corvette. I take it to mean it's of broad interest to the community.
                        The other DZ.
                        Dave Zuberer
                        • Tom P.
                          • April 1, 1980
                          • 1814
                          #27
                          Oh, OK, I see.
