69 headlight washer hoses and routing - NCRS Discussion Boards
  • Mark G.
    • January 31, 2007
    • 177
    I have many questions on hose lengths and routing. I picked up a pair of metal headlamp bezels and a hose kit from Dr Rebuild. I have the striped hose routed along the left wheel well from the headlamp washer pump through the rad support. Looking at the AIM drawing, where does this hose end at for the check valve (how much hose is forward of the rad support)? It looks like the hose for the right side runs along the harness to a T. How long are the hoses from the check valve to each T and from the T's to each nozzle? Are any of these hoses striped? The bezels I got came from a Corvette with a 5 port washer pump and they all have a red stripe on them, the hose kit I got uses all non striped hoses after the check valve. Which would be correct, striped or not striped?
