Everyone;
1963 Borg Warner transmission reverse shifting arm is hitting the frame.
As far as I know everything is stock except the transmission to frame rubber mount.
When I noticed the rod hitting I identified the transmission mount as defective and replaced it with a NAPA part.
The issue didn't change much after I installed the replacement mount.
I was wondering if the exhaust hanger went above the triangle shaped piece that adapts the mount to the frame.
If this was true it would raise the mount 1/8" if there is enough play in the bottom bolt to pull this off.
However upon closer inspection it didn't look like it would assemble in this order.
To top it off the assembly order of the exhaust hanger isn't real clear in the assembly manual.
My shifting arm adjusting block will not arrive till later this week.
Right now I am guessing on the adjustment.
Pictures show the shifting rod going through the linkage two different directions.
It should be inserted from the center of the car with the hole facing towards the drivers side.
I am considering adding a spacer between the transmission and the transmission mount.
I just don't know what is causing this issue unless the linkage is not designed to go back this far on the replacement mount is short on height.
Input is always appreciated.
Rick
Rick
