Warning: Undefined array key 6774 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
What is the maximum over-bore size for a '65 396 cubic inch cylinder bores. This is the original 962 block that the car was bore with.
Why I ask is that "Bubba" performed a .030" over-bore on the block back in the 1980's but all of the bores are not the same size for the pistons that were installed at that time. The engine uses a large quantity oil and I'd like to go to the next larger over-bore size or have custom sized set of pistons made based on the amount of material that needs to be removed to get all the cylinder bores to the same approximate size.
More info to follow on the approximate cylinder bore sizes currently.
1965 962 396's and very early 942 427's have plenty wall thickness. Those blocks can be identified by the ribs in front (right above timing chain cover) and on back. Also, you could get block sonic tested for wall thickness. This is where a reputable machine shop comes in handy. I would order custom pistons and bore block as little as possible.
You will have no problems. A 962 block cast no later than June or July 1965 (with ribs) has the same inner water jacket mold as a 427. It can be bored to at least 4.310.
If it's bored at .030 now there would be no problem going to .060 but make sure that the machine shop has the pistons you want to use so they can be fitted during the honing process.
Remember the block can be sleeved if there is a problem.
I've never had anything bored and honed without having the pistons in my hand to make sure the fit was right. Any good machine shop will want the actual pistons that are going in.
Ok, I get it....
My reference was to be sure the block will bore to the piston size. Especially a expensive custom size.
I would rough bore the block then order the pistons and then finish hone to size with the pistons in hand.
Ill take my wet noodle beating like a man....
The whole exercise was to bore the block as little as possible.
I would consider going to the next standard overbore if sonic testing proved the wall thickness adequate.
As many miles as these Corvettes get on them one might have to convert them to an electric drive before it requires re-boring again.
Rick
Ok, I get it....
Rick
The Sealed Power or Federal Mogel 11:1 forged pistons are nearly identical to the TRW pistons that were original equipment. They are available in .030 and .060.
