holley 3310-2 - NCRS Discussion Boards
holley 3310-2
  • Phil A.
    • April 30, 1982
    • 121
    holley 3310-2
    Holley 3310-2 on 1970 454 with a very mild roller cam.Carb rebuilt, put 6.5 power valve, has 72 primary jets,secondary metering block, rest of carb set up stock. Car idles rich a little black smoke. What to check for richness? Thanks Phil
  • Jim D.
    • 2882
    Re: holley 3310-2
    Try turning your idle mixture screws all the way in. If the engine doesn't die, you have a blown power valve.
