Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Stringer stripe on 67 Corvette -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Nobody even mentioned anything about this one. Ironically all Bowling Green as ever painted is base coat clear coat.
I think John meant St. Louis.
Mike
The St Louis plant was the only site doing '67 BB painting because of the stinger. There is words on a possible couple trial run BB's done at AO Smith but not typical production. There was some coverage by Roy Sinor on one of those AO Smith BB cars some time back. But again not a typical build thing at any where other than St Louis.
Mike
Yep, agreed, my early BG '81 Bowtie has a fantastic paint job. In fact some experts have told me the early BG '81s had more than twice the amount of paint than a typical St. Louis car had that year. And it was done much more professionally than St. Louis ever did.
