Question on new electrical harness - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    Guys,
    I'm getting set to order a new electrical harness for my 69 4spd coupe non-A/C. I'm planning on having the car judged and then installing a factory A/C in it. I'm thinking of ordering the A/C equipped wiring harness right from the start and then hiding the wires discretely under the dash until they are needed. Ditto for the vacuum lines. I'm thinking it would be easier to order and install these items while the car is apart. Is it feasible to do this? Will I be able to use the A/C equipped wiring harness in the non-A/C setup to control the heat and everything else until I install the A/C? Your thoughts are appreciated.
    Mike
