Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
It almost looks like someone cut the top leaf as there are only 6 leaves on that one you pictured. Or it may be a non original and someone added a spacer to get proper overall thickness.
Is that Lonoclad (the gray) you painted the leaves with or is that just gray paint trying to reproduce what was never there? Or just maybe trying to keep them from rusting?
The Lonoclad was applied to the bottom of the spring leaves to possibly stop noise? Never thought too much about that. Thought the liners were there to keep the noise down.
You just trying to simulate the sloppy work done by the St. Louis workers I guess by painting the entire spring?
JR
Service HD spring I purchased from GM SPO in the 80's came with that extra spacer. Not sure if that was production for later years. Left it off for my 63.
I wonder if they included that spacer due to thinner leaves and to ensure original length bolts would not break the differentials.
Originally posted by Joe Ray (1011)
Rich,
JR
Jr, No just Rustoleum gray to protect, not meant to be "typical". Hmmm, sloppy? I thought they looked kinda "concours". It did get a hit in judging of course.....too "shiny". Of course the sheet said NTFP.
Here is a '67 F41 for reference.
That looks alot better thanks for sharing the photos Richard, was just wondering about that top spacer if it was factory or not and also didnt they remove the plastic liner between leaf 6 and 7 on the F40/41 spring by NCRS judging standards.
I see the 354130 was a service replacement for 1963 to 1975 with HD Suspension(here). Maybe my hunch was right about overall thickness and the 0.306" top plate was added to match original thickness.
