Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
block stamp is J146 -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
A 1967 427 block stamp is J146 - Oct 14/66 front stamp pad reads T0217 Feb.17/67 and birthday of car is- Feb.21/67 there are 4 months differents from block stamp in Oct.14/66 to pad stamp in Feb.17/67 does this sound correct or it's is to far apart,
My 1967 427/435 K19 (California Smog equipped car) has it's original block cast and assembled in October 1966. The birthday of my car is in May 1967. I have seen another similar October 1966 engine in a May 1967 birthday K19 car.
Rick
What is the lap time between Block date cast # and the Front pad date # why are the days so far apart, i was told at the factory in 67 the block cast date # would of been stamp and a day later front pad would be stamped and assembled ,
Danny,
The only real relevance of the block casting date and the front pad stamp is that the cast date MUST precede the pad stamp date. It is unusual for a block to be cast and then not used for several months but, certainly, not out of the realm of possibility.
Leif
Suggest you get and read the 1967 section of Noland Adam's Book on C2 Restoration. This section includes his survey cars, where SB and BB cars have information on their dated components. The C2 Registry is another source of similar, yet different, information.
Tonawanda BB blocks were cast in batches and then assembled into engines (with front pad stamped at this time) as the need arose. So there can be a bigger gap between engine cast date and engine assembly date for the BB cars than for the SB cars. But this gap is typically 1-2 months. Noland's survey shows this as a function of the car VIN Number. It is good reading and may help you to see when some of the BB engines for cars near your VIN were actually cast and assembled. A K-19 engine may have a larger date gap than for a regular (non-K19) engine.
FWIW.
Larry
Thank you very much for the info. guys great help Danny
My block was cast J 12 6 with an assembly stamping of TI0I9JA. My car was assembled 5-25-67. I have the Corvette Order 7 copy to verify.
Look at the build date and stamping on the K19 car in the link below.
that a big jump from casting date to assembled date, mine JE
Danny,
I agree but apparently not that unusual with a JA car. I got my car from the original owner who had parked it in 1970. There is absolutely no question to me as to the originality of the engine.
Rick
I had nine months between casting and build on a 1968 435 and the stamp was good as gold. The car was built the last week of production. They're inventory system was not the best.
