Re: Brake bleeding poor results
It can make all the difference in the world. They certainly can the cause of your problem. If you don't want to change the rubber hoses due to age and getting them loose, it is likely all the more reason to change them. How old are they? They are a bit of a pain but should not be all that bad. Just make sure you use a flare wrench. It sounds like you had the problem with the original m/c and also after changing it. If it's not air in the system and no leaks, it pretty much has to be a hose that is expanding internally.
