Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
1967 L88 corvette -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Our favorite non-original L88 Shriner Corvette is back on the market again. The 1967 “L88” Shriner COPO Corvette crossed the block at Mecum’s St. Charles auction on Saturday where it reached a high bid of $80,000 but failed to reach its reserve price. Longtime readers of CorvetteBlogger may recognize this as the same car whose […]
I believe that there are a few guys that have these VIN numbers. But they don't publicize it except to others in their group. CF C2 Section had a discussion on this a few years ago, and most cars were identified. You should try over there and do a search in the C2 Section if you are serious about getting the answer.
It may take a bit of work. and a few private messages.
Larry
I was just wanted to see if anyone had know about a registry on the 20 1967 L88 just like the 1963 Z06 Tankers has, thanks Larry
I don't give my vin out, no real reason except why does anyone need or want it would be the question. new owner when I sell will be able to do as they please. That even goes for my 1983 385,000 mile toyota supra.
