What were the delivered heights of a 1968 roadster and a 1973 coupe? Is 48" for each of them a realistic number?
I am considering buying a lift so I can own two C3s. That's right, joining the club of one to drive while working on the other.
I own a 1968 and want to acquire a 1973. Vertical height in my garage is tight so this will be very close. My '68 measures 46", but I've been told my rear suspension is soft. When I rebuild the suspension, I don't want to be surprised. Various sources put the delivered height at 47.9". I've found two different numbers for the 1973: 47.4" and 47.8".
This is so close I may have to deflate the tires slightly.
A better solution may be to change the structure of my garage ceiling - - that gets complicated as my house was not built with trusses. If you have other suggestions, I'm all ears - - your budget is no more than $1,000 USD over the cost of the lift, so that eliminates building an outbuilding, buying a garage condo, moving, or filing for divorce so my wife's parking spot is available. And please don't suggest parking the second at my girlfriend's house as that would lead to the 'filing' mentioned earlier.
