C2 Door Panel Fasteners - NCRS Discussion Boards
  • Gene K.
    • August 31, 2006
    • 34
    The Al Knock door panels of my 63 Coupe have approximately 20 fasteners that CC calls Door Panels Grommets (attached photo # 1) They are approximately 1/4 " long tubes that are flared on one end facing the inside of panel to accept the screws. My question is do the phillips screws have ferrels or trim washers (photo #2 attached to them that fit into the so called grommets or do the screws alone fit into the panel grommets?
    • 6940
    Re: C2 Door Panel Fasteners
    Gene, the ferrels are part of the factory door panel and just a oval head phillip's head screw. I am not sure if the reproduction door panels have the ferrels pre installed or not.
    • Gene K.
      • August 31, 2006
      • 34
      Thanks much
      Easier than I thought
      Gene
      • Frank D.
        • December 27, 2007
        • 2703
        Al Knoch 1963 deluxe coupe door panel still in the plastic bag right out of the box...
