Can the ci steering column be removed thru the engine compartment? Is there something on YouTube showing the removal of the column? Thanks Kevin 775
C1 steering column removal??
Re: C1 steering column removal??
Kevin, Yes it comes out from the engine bay. It makes it easier if you take the Pitman Arm off to clear the exhaust manifold. You'll need a Pitman Arm puller.
I haven't seen any videos but something may be out there.
Rich- Top
Kevin, may be best to pull the manifold in your case as Jim suggested.
Rich- Top
Kevin,
You don’t specify the year. A 53-57 column is more difficult to remove than a 58-62 because of its additional length and because of the way it interfaces with the instrument area. Either can come out with engine in and body on. The only way to remove a C1 column is through the engine compartment.- Top
Mike you're right he didn't state the year in this thread but in another one earlier he asked about box repair and he stated '58.- Top
