Re: Quiet Air Compressor
An added item we use with our bead blaster is connecting a Bullard Air Line Filter between the compressor and bead blaster. It sure helps with any moisture getting into your line and clogging your media at the bead blaster gun. It also works great when painting - connect the Bullard Air Line Filter between your compressor and paint gun - works the same way keeping the moisture down. The Bullard units are generally used as a dryer for breathing air when using a sandblasting hood.
I even used it when soda blasting my car. It worked great.
Jill, 59140
Jill, 59140
