C3 Headlight Header Bar/Reinforcement - NCRS Discussion Boards
  • John S.
    • June 15, 2015
    • 505
    I am in the process of helping a fellow C3 owner on another forum with the R&R of his headlight assemblies and the subject of the front header/reinforcement bar came up.
    John
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
  • Gary R.
    • April 1, 1989
    • 1796
    Re: C3 Headlight Header Bar/Reinforcement
    John
    73 I believe was the year of the change where they were just glassed in. The 68-72 had the bonding strip with the aluminum rivets. I removed my 69's header bar years ago in preparation for a full body off, which I haven't got back to yet. I chiseled them from underneath so I didn't break the surface.
    • John S.
      • June 15, 2015
      • 505
      • Bob W.
        • December 1, 1977
        • 799
        Gary Was the header bar bonding strips riveted and bonded or riveted only?
        Bob
        • Paul O.
          • August 31, 1990
          • 1716
          Bob
          On c3 before 1973 the header support had a Fiberglass strip attached to complete the assembly. I think C2 also had a similar type assembly.
          • Gary R.
            • April 1, 1989
            • 1796
            Bob,
            Pauls pictures show it, the bar was riveted to the large bonding strip which was then glassed to the nose so the rivets were sandwiched between the nose and the bonding strip.
            John
            I also have a 72 and the rivets are starting to show a little.
            • Bob W.
              • December 1, 1977
              • 799
              Gary When you removed the rivets and the header bar Is out are you now going to glue the bar back to the bonding strips?
              Bob
              • Gary R.
                • April 1, 1989
                • 1796
                Bob
                I did that job about 14 -15 years ago and put the car away. I bought a NOS bonding strip so my intention was/is to glue the bonding strip on instead of rivets and then line up the buckets, mark it and glue it to the nose. I believe going back beyond that time the new bars were/are made to compensate for the thickness of the bonding strip so it is no longer needed.
                • Paul O.
                  • August 31, 1990
                  • 1716
                  A little trick to fool a judge is to epoxy the bonding strip and header bar together. After it cures cut the epoxy that comes through the rivet holes. Then take some rivet shafts cut them then compress them as if they were riveted and then epoxy them in place. This is only needed to be done if you are having the car judged I do look at that when judging. Not sure about other judges.
                  • Bob W.
                    • December 1, 1977
                    • 799
                    Paul So after the header is glued in place do have any tricks to remove the ghost circles from the top surround?
                    Bob
                    • Paul O.
                      • August 31, 1990
                      • 1716
                      Yes after a period of time they will shrink back to normal. If you let it sit in sun this well happen faster.
                      • Bob W.
                        • December 1, 1977
                        • 799
                        Paul So remove the header as Gary Ramadei did then glue it to the bonding strips and in time the bumps will just shrink and be gone. Will a heat gun help speed it up?
                        Thanks for the tip Bob
                        • Paul O.
                          • August 31, 1990
                          • 1716
                          It may but get it to hot could cause damage. Once the pressure is released from the corrosion of the rivet heads the process will start shrinking the bumps. I let it return to normal after a few days.
                            • 15573
                            1973 for the change to go along with the change in the nose to accommodate the "rubber" bumper.
                            • Patrick B.
                              • August 31, 1985
                              • 1986
                              Do you have to take the radiator core support out to remove the header bar?
