Where does this piece of spark plug shielding go on my '69? - NCRS Discussion Boards
  • Paul S.
    • October 29, 2015
    • 203
    Hi all,
    Can anyone tell me where this piece goes on my '69 base model?
    I am told it installs on the "passenger side rear" and holds the spark plug wires on that side. I cannot find it in the '69 assembly manual, though. If anyone can point me to the right page or otherwise describe how this installs, I would greatly appreciate it!
    Thanks in advance,
    Paul
    Re: Where does this piece of spark plug shielding go on my '69?
    Originally posted by Paul Shatlock (61745)
    Hi all,
    Thanks in advance,
    Paul
    Paul----------
    This support, GM #3864498, installs on the right rear of the engine on the top of the bellhousing flange (on the ENGINE BLOCK, not the bellhousing, itself). A single 1/4"-20 hex head screw retains it. There is a tapping on the top of the bellhousing flange for the screw and there is a shallow hole into which the tab on the end of the support fits. In this manner the single screw-retained support is prevented from rotating. You will find a depiction of this on UPC 6, sheet B6 of the 1969 AIM.
    • Paul S.
      • October 29, 2015
      • 203
      Thanks so much, Joe... this is extremely helpful!
      - Paul
      • John S.
        • June 15, 2015
        • 505
        1973 L82 M21 4 Speed, very original and well documented driver/survivor
        NW Chapter Member, 2016 Bend Regional Top Flight
        73/74 TIM&JG 3rd Edition Revision Team Member
        • Paul S.
          • October 29, 2015
          • 203
          Awesome... thanks so much, John!
