I bought a 69 BB car with a L36. Its a numbers matching car except the usual everyday parts wear the was changed to replacement parts. I have a question as I replaced the valve covers, I noticed that the casting number on the cylinder heads are different then what they should be. I have casting numbers 3964290 which says 69-70. My corvette was a late production built in Nov25 69.
My question, The owner said that that were original and that the cylinders heads were not replaced. Could GM started using them at that time? Did they run out of the what should of been?
Mark
Mark
