Index for Noland Adams Restoration Guide # 2 1963-1967 - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3607
    Re: Index for Noland Adams Restoration Guide # 2 1963-1967
    Here's the PDF I converted it to....
    Thanks for doing that, Rich...saved and printed.
    Leif
    • Gerald C.
      • June 30, 1987
      • 1273
      If I save it as a pdf, members won't be able to sort at will. I don't mind responding the emails. Glad to help.
      Jerry
      • Gerald C.
        • June 30, 1987
        • 1273
        #18
        Thanks Rich! You're much better at this stuff that I am !!!
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          #19
          Hi Jerry, Your welcome. I was hoping you were okay with me posting the converted file.
          And THANKS AGAIN for your efforts to make it for us all!
          Rich
          • Joe R.
            • May 31, 2006
            • 1822
            #20
            Hi Jerry,
            I sent you an email but have not received it yet. Are you still working through the emails?
            Thanks again for doing this!
            Joe
            • Mike B.
              • July 31, 1994
              • 838
              #21
              Thanks Jerry for creating this index! This will certainly help. I've been referring to Noland's guide since the late '80s. Sure would've come in handy way back then.
              Thanks Rich for converting this file to PDF. I was able to grab it off of this thread. Excellent!
              Mike
                • 15610
                #22
                Originally posted by Gerald Coia (11656)
                Everyone....
                I cannot seem to attach this spreadsheet to my PM replies. I contacted the administrator for guidance. More to follow.
                Jerry
                That's why I don't use the PM function. You can't attach files and there's nothing the administrators can do because it's built into the software. Others should contact you using the "send email" function. That way you can reply using conventional email and include attachments.
                • Donald O.
                  • May 31, 1990
                  • 1580
                  #23
                  Gerald
                  e-mail sent
                  Don
                  • Brad V.
                    • May 2, 2015
                    • 30
                    #24
                    I have used the attached PDF to convert to DOC and XLS format and bundled all (3) together in the attached .ZIP (a NCRS forum supported format).
                    I agree, having the .xls allows you to filter based on year (top column) along with options. Thanks again for putting this together.
                    I hope this helps, Brad.
