Battery Hold Down/Shield Plated? - NCRS Discussion Boards
  • Larry M.
    • January 1, 2002
    • 535
    On a 64 mine is plated (yellow, likely yellow zinc) and then painted black. They AIM calls for two parts spot welded together and I guess then painted. So I'm pretty sure I have a repro but the question is this. Should there be plating?? I doubt it. Paragon sells a repro which is plated and that may be where mine came from.
    Re: Battery Hold Down/Shield Plated?
    Larry------
    I'm not real familiar with this part. However, I can tell you this: GM component parts may be either plated or painted. Sometimes, the GM spec for the part allows the manufacturer to apply either finish, optionally. However, I don't know of a single case in which any GM part receives both plating and painting. If painted, it's usually over bare metal.
    • Joe R.
      • July 31, 1976
      • 4547
      Yes, repos are yellow cad but there should be no problem painting over the yellow cad.
      Originals were black. They were originally dipped.
      JR
