I have a 61 on a rotisserie and am now repairing some under body damage. I am the second owner of this car and found that the previous owner had the entire under body coated with rust preventative coating. After a major investment in time it has all been removed. I finished the soda blasting and it looks great. However there are some repairs needed to the under body. I want the repairs to have the same appearance as the original look of the fiberglass as I would one day like to have the car judged.
I tried some color additives to the resin from Fiberglast for the repair work but just can't get the right match. Additionally their resins have a pink cast which shows through on the repair work. Can anyone suggest the best method to get the desired original look? Also, after the soda blasting it looks like the entire under body needs gelcoated as the fiberglass strands are no longer sealed. I am thinking a clear flat gelcoat and I am having difficulty locating the right brand. Can anyone help advise on this and where to go for the right gelcoating? Plenty of companies have gloss clear but can't locate anyone with a flat clear, if this is the best way to go.
