Trim Tag 1965 - NCRS Discussion Boards
Trim Tag 1965
  • Bill S.
    • August 31, 1999
    • 104
    Trim Tag 1965
    Well here goes ... got to get in the door with a correct trim tag to be judged.
    How does the attached look?
    Did some research about the "teeth" in the "C" of Chevrolet and the centering of the "M" and the "H"
    This tag appears to have both.
    Anybody see anything that "Jumps" at you?
  • Mike D.
    • July 31, 1996
    • 303
    Re: Trim Tag 1965
    Typical production trim tags have the paint code below the 1st and 3rd digits of the body number instead of the 2nd and 4th digit. In my registry, I have bodys 4467,4445,4910, 4930,5287 are all showing this configuration. This covers VINS, 14008,14276,15391,15404, and 16517. You will noticed the indents in the tag. Factory installation of the tag usually does not have the indentation.
    Mike Doty
    Intermountain Chapter Judging Chairman
    Region VIII Director
    • Mike D.
      • July 31, 1996
      • 303
      Re: Trim Tag 1965
      Body build date looks correct as 4467, and 4445 are also H24.
      Mike Doty
      • Gene M.
        • April 1, 1985
        • 4232
        Re: Trim Tag 1965
        The pins in the rivets don’t look right. When ever I see that the possibility arises does this tag belong on this car.
        • Joe R.
          • July 31, 1976
          • 4547
          Re: Trim Tag 1965
          Here is a 65 Trim tag. How about those pins in the Rivets?
          SN 18487
          JR
          • James W.
            • December 1, 1990
            • 2640
            Re: Trim Tag 1965
            Bill,
            I'm kind of late to the party, but here are a couple of photo's of my A.O. Smith trim tag on my '65 coupe VIN 2209x. Sorry but IO can't get the photos to upload in the correct orientation.
            James
            • Mike D.
              • July 31, 1996
              • 303
              Re: Trim Tag 1965
              Morning Jim, better late than never.... MY research shows with A.O. Smith bodies in 65, the body build number started under the dash, then moved 1 space to the right in the middle of production, then back under the dash around VIN 18,000. Thanks.
              Mike
              Mike Doty
              • Jim S.
                • March 13, 2013
                • 360
                Re: Trim Tag 1965
                Mike
                Sorry, having a senior moment...can you explain what you mean? Does the body build number actually begin down one line and below the dash that is between the A and the number?
                • Mike D.
                  • July 31, 1996
                  • 303
                  Re: Trim Tag 1965
                  Sorry, the paint code is what I meant that is under the body build number. The original post had the paint code farther right than normally seen.
                  Mike Doty
                  • Jim S.
                    • March 13, 2013
                    • 360
                    Re: Trim Tag 1965
                    My 65 AO Smith car is VIN 5756 and has the paint code starting to the right of the dash.
                    • Mike D.
                      • July 31, 1996
                      • 303
                      Re: Trim Tag 1965
                      Jim, what is your body build date? It looks like AO Smith moved the paint code numerous times during the production run. on VIN 56, paint code started under the A, then 1104-4251, started under the dash. Then your car starts under the first number. 16861 is back starting under the dash, and it looks to have stayed at the position the rest of production.
                      Mike Doty
                      • Jim S.
                        • March 13, 2013
                        • 360
                        Re: Trim Tag 1965
                        E22 is the body build date.
                        • Keith W.
                          • June 30, 1998
                          • 375
                          Re: Trim Tag 1965
                          114661 - build April 7th - job number #356
