the 69 i am restoring was missing the luggage rack. There are only four mounting holes (two on each side). The only after market units I have found are either 6 or 8 holes and none of these will fit my holes( my holes are too wide). I know that these were dealer installed options. Can anyone help me find the correct rack for my car. Thanks
1969 corvette luggage rack
Tags: None
Re: 1969 corvette luggage rack
You might consider placing a free member ad in The Driveline. I would think some folks might have one removed from their car for judging.the 69 i am restoring was missing the luggage rack. There are only four mounting holes (two on each side). The only after market units I have found are either 6 or 8 holes and none of these will fit my holes( my holes are too wide). I know that these were dealer installed options. Can anyone help me find the correct rack for my car. ThanksTerry- Top
All stock (dealer installed) racks used more than four holes.the 69 i am restoring was missing the luggage rack. There are only four mounting holes (two on each side). The only after market units I have found are either 6 or 8 holes and none of these will fit my holes( my holes are too wide). I know that these were dealer installed options. Can anyone help me find the correct rack for my car. Thanks- Top
I understand the 68 and 69 luggage racks were also used on Corvairs. Might try and search that avenue.
Russ, 68-69 luggage racks were typically different than the 70 up racks. They were mounted at the four corners. See the pictures in the new judging manual.
Gary B- Top
Thanks for the info Gary. I don't think I have ever seen a 68-69 then.I understand the 68 and 69 luggage racks were also used on Corvairs. Might try and search that avenue.
Gary B- Top
Larry
2002 Z51 Convertible
1969 L46 Convertible- Top
Lawrence, is there a web site i can view the 69 brochure? I have tried to find a picture but have had no luck.- Top
As a reminder, PDF versions of Corvette brochures (low & high resolution) can be found at the GM Heritage Center.
This same location also has some of the older Corvette News magazines.
For the FREE Corvette Information Kits (great technical data), CLICK HERE
(scroll down to Corvette and select SHOW to see the many links)- Top
